Front camera connected with the car C area, then the No. 1 plug with canbus need to be used. The front camera needs 1080N format to support displaying.
Check Front camera View
Description of the interface
Setting interface
Recording settings, it needs an external USB disk and select the recording device to start recording. It is recommended to choose a high-speed U disk, otherwise it will lead to recording errors. In addition, this recording will conflict with the 360 recording channel. When you buy 360 panorama accessories, the front and rear recorders can't record, you need to switch to reverse vehicle mode in the factory settings.
Display Settings
Image Settings
